The GTS is awesome, but it’s not nearly £20k more awesome than that red C2S which arguably has a more desirable spec. The bucket seats are a very rare option on such a car. Not sure I’d go crazy over the PCCB option, but you shouldn’t need to change the disks ever. If you really wanted the extra horses in that C2S (if 385 wasn’t enough for some reason!) you’d have plenty of change in your pocket to do it.
The main difference that I can see is that one is a convertible and the other isn’t... both are very nicely specified 997.2s. Again I would reiterate that you’re not a million miles away from a GT3 (albeit a 996) or a nice 997 turbo if you’re able to spend £62k and those really are special cars. Especially if you’re considering a fixed roof version.
That red C2S looks like a brilliant example and makes the GTS look very costly.
EDIT: there are a couple of pretty special 996 turbos on JZM’s site too...
whats not to like. I bought my GTS because finding the right combination of price/spec/miles/colour was practically impossible, and if you couple that with the better residuals then it can actually be cheaper in the long run.
