Anyone upgrading to the new Pro model. Next time the standard one is on offer i think i will pick up the bluetooth one.
Probably a bit late now, but....Currently got a bit silverside going at 55, I decided to pre sear for the first time just because on a bigger piece of meat it seems easier to get a nice sear all round before it's cooked, just rubbed in salt, pepper, fresh thyme and fresh rosemary.
Still deciding on how long to leave it on for and if I should do a post sear too, what'd you guys reckon?
I normally do beef joints of ~1kg, just the 2 of us and leaves plenty for sarnies. Last time it was from frozen so it was 12 hours. 8 hours is what I'd do from fresh @54°C *this is from memory, pretty sure it's right*
I also post sear, never really done any pre searing.
Can anyone recommend zip lock bags suitable for a leg of lamb?
Bernzomatic TS8000
Imported from the USA, significantly cheaper. Use Mapp gas from screwfix. Does the job.
Can anyone recommend something efficient to use the sous vide in? I have the anova precision cooker and need something it will easily sit in and not leak heat.
amazon won't ship to UK. did you order form somewhere else?
Nope. It was from Amazon. I think .com rather than through .co.uk
Wasn't hugely expensive.
Do you not have a vacuum sealer? I guess not if your asking. Zip lock by baco (i think they are the original zip locks bag im not sure tho)do some bloody massive bags that might fit your needs. I use a smaller version to do my eggs benedict and they hold up fine. With meat however just be sure to get as much air out as possible using displacement before sealing.
