Caporegime
- 18 Sep 2009
- Dormanstown.
His posts today reflect exactly that.
His posts reflect that he's a cracker.
Does indicate the 8 core will be better thoughComes down to the design. There's additional latency there. That's not to say the higher SKU aren't any good for gaming, though.
Don't really see the point in having the 3700x and 3800x![]()
@humbug remember week or so ago when I said them cpus will eat loads of power ?? If this takes 245w @4.1 in CINEBENCH you are looking at 320w in IBTat damn 4.1. Vcore is 0.03v higher than my daily one.
SoC needs more Vcore I see. Atm I'm sitting at 1.025 here its at 1.2.
Not sure about Cooling but its 82c so thats More than I got at around same watts by 8c
you'll be fine, guessing your heading to x570 rog formula ? 12 phases 50 amps i think, not done as much with asus these days
Pretty mad that the gaming world is buzzing with excitement. For the fact that. AMD just matched a cpu already on the market from intel. For around the same price.
I dissapoint.
Well it’s £100 cheaper ....3800x v 9900k but it’s not making me moist![]()
I dissapoint.
£170 cheaper if you get the 3700X
i assume there is 1 massive difference between 3700x and 3800x.£170 cheaper if you get the 3700X
The design.... Id rather have 1x8core chiplet than 2x4core ones Totally worth the extra price !!! 1x8 will be superrior on latencies simple as that.The name?
The name?
