When will reviews drop on these? Presumably no one even has them yet.
July 10, i think it was said.
Reviews after launch?July 10, i think it was said.
9900kDoes anyone know which will be best for gaming? 8/12/16 core? Lisa indicated that the 3800x was the top gaming chip. But the 3900x has 100Mhz more. im confused. I just want the best gaming chip.
You can buy this very inute even
with fast memory I don't see the 9900k beating AMD this time round. not from what we saw. Will be close but I think AMd will win if you tweak.9900k![]()
Yeah anyone can just buy one and do a review lol.Reviews after launch?
That makes even less sense than pre orders before reviews![]()
Until the reviews come out and its properly benchmarked then surely until then its just educated guesses and assumptions?Does anyone know which will be best for gaming? 8/12/16 core? Lisa indicated that the 3800x was the top gaming chip. But the 3900x has 100Mhz more. im confused. I just want the best gaming chip.
40W is massive difference.
It comes from something.
I think it should Overclock better due to 2x6 core contact area with IHS will be 200% basically. So cooling should be easyer.You might want to re-read the question.7nm process is clearly where it comes from.
I was all aboard the hype train until Linus said, and all the motherboards have a fan. Erm. No thanks. Also, for 11 watts is a fan really needed? The Surface Pro from 2017 used a 15 watt CPU and was fanless. PCs kinda have a load of air going through it. Kill the fan please.
Can't make up my mind anymore. I was thinking about the 12 core, but am now looking at the 8 cores. It would be a mistake for me to splash out £450+ when the only real multi tasking I do is play games with a lot of internet tabs open.
It's so difficult to just say to myself 'wait for reviews, you idiot. That's all that matters at this point'. It's fun to speculate but in the end you just have to be patient and wait![]()
