- 27 Aug 2009
- Liverpool
To stop the loop i put it back in gameboost mode an it works
Yep, my suggestion of the 4 pin was a troubleshooting process to see if we could smooth out the power delivery (not just more oomph) - but as Danny mentions it shouldn't be a requirement.Testing a different PSU could be your first port of call once/if you set out on hardware replacing troubleshooting. There's really no need for a 750W, or to use that extra CPU 4 pin header, if everything was fine. Need to track down what's going on as it could come back to bite you later even with Game Boost on.
Always, a good test to try. Or even profie 1 at 1.35V if that fails.But then also manually enter a value of 1.35v for the RAM (in your pics it's DIMM 1.216v). See what happens.
No need to apologise, Danny - i was actually validating your postSorry, didn't see that suggestion, Plec. As an experiment wouldn't hurt, no.
Temps?Restarted 10seconds into prime 95 torture test so close yet so far
Yep, it's a tough call - and unfortunately he's bought from multiple e tailers.It still seems to be pointing (for now) to that particular CPU needing more power than normal to be stable. So it could be a very weak CPU and refund-worthy, or PSU-to-CPU power delivery issue. Could always be motherboard however it seems fine enough to inform you of a CPU issue which is somewhat reassuring when it comes to the motherboard (even if inconclusive).
I would ring and ask their returns policy before doing this. You would have more luck with this via distance buying (A PITA i know).might just nip to local elec store now and buy a new psu just for the sake of it then try returning if no good
looking at a local currys store near me doing some corsaid and EVGA gold rated 650 / 750 for a decent price, returns in 14days if opened & faulty (im sure i can return it )
This does sound good - but i would clarify with local store goon - then you have a name to go back to if they dispute it later.looking at a local currys store near me doing some corsaid and EVGA gold rated 650 / 750 for a decent price, returns in 14days if opened & faulty (im sure i can return it )
Not surprised - it's a bitch of a problem. And you've certainly tried your damndest to resolve it. You deserve a bit (a lot) of luck - so here's hoping the PSU test pays off...sigh >.< my head hurts
Leaves the CPU in the library and the Motherboard in the kitchen - but we could test the memory hiding in the study.Well its installed...
didnt boot up in the normal mode..
Restarted on prime 95 blend test after about 1 minute cpu temps around 60
