Caporegime
- 13 May 2003
- Warwickshire
Ok I've had another play this morning. Dialled in the grind quantity to give 17g (which causes the last bit of coffee to go everywhere as the basket spills over), set the grinder to 4. Between setting 4 and 3, the espresso moves from an overly quick extraction to a ristretto choke, where the machine can barely get water past the coffee.
There's no backflush plate in there to my knowledge. Just a black plastic disc with a hole in it underneath the basket, which looks like it should definitely be there.
I've played with different tamping force to no avail.
It must be the beans.
Next thing I'm going to try is programming the double shot volume to give 35g of espresso.
next thing to check is the amount of coffee your getting out on the 'ristretto choke'. May also be worth reducing the amount of coffee your putting in the basket a little, try going to 15g?
