Its my biggest hope thats why i want to see Aida memory benchmark most out of all benchmarks.Is IF not meant to be disconnected or at least partially from memory clocks this time?
Not seen much info about standalone 4 core parts i dont think AMD would just throw those away.I would expect them to be awful salvaged parts, 50% cores crippled means the silicon is very low quality.
https://www.extremetech.com/computing/253248-amd-threadripper-delidded-multi-core-surprise-hoodi also dont see them binning them
You don’t know that.
She doesn't even know you exist
Put 8 of those 4-core chiplets into a Threadripper for 32 cores.Not seen much info about standalone 4 core parts i dont think AMD would just throw those away.
@CuriousTomCat as I said 2 chiplet 8 core could be great. Remember how TR most people ware wrong about Threadripper before one got delided ??
I hope so. She doesn't have to. I hope that, at least, she knows about the presence of the other 7,709,335,087 people on the same planet.
Well, we do?
You can't force games to use more resources.
I see what you did there. Highly relevant to whether the 3800X is the "gamer's choice" out of the Ryzen 3000 range of CPUs. If English is not your native language, that phrase indicates that the best (fastest) chip for gaming is the 3800X. Not that that statement is tailored to your individual requirements or to any other inhabitant of this planet or any others!
Ah now lads! Not long until the E3 event. We'll hopefully get some more information then. No need for all this
Plus we all know neither Intel, nor AMD, can compete with the juggernaut that ia VIA.
So you know that the 3800x will be faster in games over the 3900x do you?
Know you don't
Hard to say tbh 3900x will be using 2 chiplets thats 100% sure and cause of that design its possible it will have less/core problem with heat when pumping volts than 1 chiplet cpu. I think it can handle more volts cause of this. Need to see what both can do at 1.425 volts heheWe can apply logic?
If facts transpire that the 3800X has higher performing per core performance, it's inevitable it's going to perform better in games. You can't force a game to use more threads/cores........
Sure if a game can max out a 3900X then it's going to perform better than a 3800X. But this is all basic logic.
Unless you're just having a poor attempt at trolling.
