M2 will probably be the 500GB Samsung Evo 970. It’s £140 atm.
If you have that budget go 3900x
I wanna see gaming benches between them first tbh.If you have that budget go 3900x![]()
RGB case can be had for very resonable price.Sorry for the real general question, but so many things are floating round my head.
I know it’s difficult to say precisely, but do you think a £1500 budget will be enough for:
Ryzen 3800X,
X570 mobo
3400Mhz RAM (16GB)
M2 drive
New Navi card
Nice RGB case
For gaming use important difference is between mechanical HDD and SSD:Are you talking ordinary SATA or NVMe though?
I am still using SSD and those videos prove I’m not missing out...the thing going for NVME is no cables...but in my case the ssds are on the back of the motherboard so I don’t have any cables on view...
Samsung Evo m2 500gb £100
Samsung evo ssd 500gb £50
Its not just no cables it's absolutely minimal space usage, which i guess doesnt matter if space isnt a concern.
2700 and 2700X are likely differently binned.TDP is purely boost clock management for new processors. 2700 and 2700x are same silicon with different boost profiles
The question for me is which coolers can shift 200W+ while keeping die temperature <60C to maximise boost.
Maximising boost will be much easier on the 3800X with 8 cores, so is likely to need high end air with good fans or a beefy AIO / CLC. Whereas maximising XFR on the 3900X is going to need a quality high flow AIO or full water-cooling.
So what sort of applications make use of all 12 cores? Is it really just heavy video editing/3D rendering, that sort of stuff?8/16 will be plenty until the refresh, at which point a better 12/24 will be likely be available. Outside of productivity, editing, streaming etc the 12/24 is likely to be very expensive for gaming with cores sitting pretty much unused. It's pretty much a certainty that no games will be released in the next 12-24 months that can't run at 100% on 8/16 regardless of card as it would damage sales. 4/8 would be out, and 6/12 would struggle. Far too much of the market isolated. Anything that does will be some early release obscure rarity for pc only that's probably not worth touching for years.
This WhyCry chap also had a slide "sent to him" of the RX 5700 XT. Both of these slides have the same "camera phone picture of something displayed on a big monitor" quality to them so I'd say they were from the same source. Whether they're actually slides from AMD's E3 event or meticulous fakes remains to be seen.Apparant Ryzen 9 3950X slide leaked:
https://videocardz.com/newz/amd-ryzen-9-3950x-to-become-worlds-first-16-core-gaming-cpu
