Permabanned
- 15 May 2006
- London
3950x has potential to be gaming king....Thats a lot of go for the bottom of the range chip![]()
they leaked Ryzen 1 and refreshOh come on learn how to add all images in one post.
Still nothing from known third parties, nearly there.
Do you think 3950x will beat 9900k in most games?Still doesn't do well in FC5 but FC5 always has been an outlier, i'm not worried about that and the 3600 has beaten the 2700X by some 22%.
For the rest, this is the entry level, none X 6 core very close to the much higher clocked 8 core 9900K. the Cinebech R20 single thread says it all, 478 vs 497, that's 4% to the 9900K but its clocked at 5Ghz ST vs the 4.2Ghz of the 3600, that is an IPC advantage of 15% to Zen 2.
Impressive stuff.
Their results were spot on....Lol my bad that makes more sense now
I do, i think the 3700X will match the 9900K in almost all games. its got the 8 cores to match the 9900K and that 5% higher clocks vs the 3600 to take it there. oh i think the 3700X will be trading close blows with the 9900K in most games.
In that case, there must be a possibility that the 3800 could just pip it.I do, i think the 3700X will match the 9900K in almost all games. its got the 8 cores to match the 9900K and that 5% higher clocks vs the 3600 to take it there. oh i think the 3700X will be trading close blows with the 9900K in most games.
4.2Ghz 6 core vs 5Ghz 8 core, there's more to come... ^^^^^^^
I'm going to put the 3700X at 140 FPS here...
https://elchapuzasinformatico.com/2019/06/amd-ryzen-5-3600-x470-review/
It is true that we have been able to configure everything without problems and that the operation seems correct, although later we will see that the problems of the first generation of Ryzen processors with the memories seem to reproduce in latencies and copies.
Read more https://elchapuzasinformatico.com/2019/06/amd-ryzen-5-3600-x470-review/
Put 3800x @143-145
Latancy - hence the increase in memory on L3 cacheAre they saying that memory problems still exist > I thought 3733 etc was fine ?
So you're both going to basically invent numbers and then take a position based on your invented numbers.Yeah
I think AMD have cracked it, the IPC of Zen 2 is huge.
Although the question is meant for @humbug, my answer is no i don't think the 3950x will beat the 9900k in most games. I think it will actually annihilate the 9900k in every single game and almost certainly every single meaningful benchmark.
