that's not actually as bad as i'd thought it would be. not that i'm going to be dumping nearly 700 notes on a motherboard!Gigabyte X570 Aorus Xtreme listed for £679.09 on major site
This item will be released on July 7, 2019.
Unsure how people can justify those 6-700 boards! What benefits will they actually give to your average overclocker?
There's no question that higher clocked higher SKU gets better binning.
And at stock 3700X is going to have lot worser boost clocks when number of loaded threads rises.
Just like in case of 2700X vs 2700, or 2600X vs 2600.
Heck, for gaming at stock 2600X is better than 2700 with lot better maintaining of boost clocks because of more TDP room.
https://www.techpowerup.com/review/amd-ryzen-5-2600/16.html
https://www.tomshardware.com/reviews/amd-ryzen-5-2600,5625.html
Question with regards to Ryzen 3000 and RAM sticks.
Would it be possible to buy 2x8 rams for 16gb dual channel, something like Team Group 8 pack going for £150 and then down the line in a years time buy exact same kit to stick it into the motherboard to get total 32gb? Or will I need to be a separate 32gb kit?
Makes sense, thanks a lot!Yes but that relies on being able to find those kits again in 2 years.
The memory on those 8-pack kits are made by Samsung and are known as Samsung b-die. It's been widely reported that Samsung has stopped making them now so they will become scarce going forward.
Realistically as you have MM access I can't see it being too much of an issue picking up a kit in a couple of years time when people upgrade.
I'd also wait personally for reviews to see the difference memory speed and timings have on the new processors there are some really cheap kits about at the moment, almost half the price of the 8 pack kits and could end up being only a few percent slower if at all.
No it wont, gigabyte global store listed it.....Act quick, quite cheap . Take down will be issued pretty quickly from gigabyte or amd !
What he means is that yes the scores are higher, but due to having 4 more cores. Some people, including me are interested to see if AMD can match Intel core by core, since in gaming for example having faster cores is important. For multithreaded load having more cores is better, that is not a discussion.
Indeed. For many years ~£150 would be my absolute max. You can still get very decent boards on most platforms for that price but the top end has gone wild. I suspect it's just to keep the companies profits high with AMD not changing socket as often as Intel used to.I used to baulk at the thought of paying over £100 for a mobo, times certainly have changed.
Really like the look of that board..... would look awesome in any caseAmazon US, not Gigabyte . Gigabyte don't sell directly , resellers or distribution
I still think there's something wrong about spending more/as much on your motherboard as on the CPU. I know I probably need to get with the times, but I swear since I put together my 6700k build top-end motherboard prices have gone mad.
