Good newsI would take the potato every day its great carbs...
Now sorry an exam
Simply higher clocks pulling TDP up.
I tested a couple of b450 boards for systems and these where fine with the 6 core with 3200mhz c14. Also fine with new apu. But in both instances efficiency was short by a fair bit clock for clock vs x570.
RAM wise 3600c16 kit of 8Pack stuff running c14 makes absolute sense 1:1 with IF. I tried this in every x570 board we have for test and working fine...
Do you think 3600Mhz C14 is possible with a X470 board like a C7 Hero? I got a 3600C16 kit last week in preparation for Ryzen 3000
Yes it will run 3600 C14, it will need Ryzen Dram Calculator and a hefty rise in voltage but it will do it. If you are going to be using it with a Ryzen 2 cpu, 3733 C15/16 would be much better though.
