Caporegime
- 18 Sep 2009
- Dormanstown.
So did these pre orders happen anywhere then
?Please remember that any mention of competitors, hinting at competitors or offering to provide details of competitors will result in an account suspension. The full rules can be found under the 'Terms and Rules' link in the bottom right corner of your screen. Just don't mention competitors in any way, shape or form and you'll be OK.
?So did these pre orders happen anywhere then?
Well it does not!!! 3200mhz mem max supported.........Happy my B350 takes a fully overclocked 3700X![]()
It is correct, all you need to do is visit Gigabyte's website if you are still unsure. But you don't have to as I've already done it some time ago. X370 Gaming X series of MoBos from GB are all compatible all the way up to the new 12-core.
Probably something to do with the better traces & PCB thickness (to comply with PCI-E 4.0 standards). Plus the fact that most X570 will be daisy chained as opposed to T-topology like what was on a fair amount of X370/470 boards.
Well, thanks for trying to clarify, but I still don't know what this means in practice - does it mean memory latency is higher? That faster memory speeds are less likely to be achievable? That performance is poorer even at the same CPU and memory clocks?
Same CPU and memory clocks.... poor relative perf..... Efficiency
So it looks like from doing a quick search that the cheapest x470 that supports all its the gaming Pro carbon?
Yeah that's what it looked like to me too, thanks for that. My ultra gaming gigabyte is a pile of poo it seemsx470 MSI Carbon > Taichi (basic) > Aorus 7 > Crosshair 7 -- price wise with cheapest first
I'd expect GB be fully aware of what their own poducts are capable of handling before releasing a new BIOS supporting new CPUs.It’s not whether the Gigabyte website says so, it’s down the whether the VRM’s etc will handle it. Says the AB350 Gaming will support the 12 core, but would you run it on that? No. It’d have an aneurysm.
Any hints how much poorer we're talking? Few percent?
We shall see. I am able to run a good memory kit at 3500 MHz CL16 on Ryzen 1700X. Now I do expect Ryzen 3800X to have much better memory controller so I don't deem 3600 MHz CL16 or even 3733 MHz CL16 unthinkable.I think the higher memory frequencies will be harder to achieve on 370/470 personally. I think performance (CPU) wise, maybe a couple of percent. Wait until Sunday and go from there. Pretty confident 3200C14 will be perfectly fine for most users.
We shall see. I am able to run a good memory kit at 3500 MHz CL16 on Ryzen 1700X. Now I do expect Ryzen 3800X to have much better memory controller so I don't think 3600 MHz CL16 or 3733 MHz CL16 is unthinkable.
