OcUK Staff
- 23 Feb 2015
- Overclockers UK HQ
Hi all,
I've spent this morning setting up some new LG monitors for pre-order on OCUK. Two of which will be UK exclusives at OCUK!
The two exclusives will be landing at OCUK around the 16th July (27GL850) and 13th August (34GL750). Stock is fairly limited so pre-order soon to guarantee one at launch. Second waves of stock should be around a month after each date.
Check out the exclusives and the other LG monitors added to the range below!
all lg monitors
exclusive to ocuk
LG 34GL750-B 34" 2560x1080 IPS 144Hz 1ms HDR10 FreeSync/G-Sync Compatible Curved Widescreen LED Gaming Monitor @ £509.99 inc VAT
Display Resolution 2560x1080, Display Size 34", Refresh Rate 144Hz, FreeSync, G-Sync Compatible, Response Time 1ms, Contrast Ratio 1000:1, Panel Type IPS, Curved, HDR10, Height Adjustable
Only £499.99 inc VAT.
ORDER NOW
LG 27GL850-B 27" 2560x1440 NANO IPS 144Hz 1ms FreeSync/G-Sync Compatible Widescreen LED Gaming Monitor @ £449.99 inc VAT
Display Resolution 2560x1440, Display Size 27", Refresh Rate 144Hz, FreeSync, G-Sync Compatible, Response Time 1ms, Contrast Ratio 1000:1, Panel Type IPS, HDR 10
Only £449.99 inc VAT.
ORDER NOW
New to the Overclockers UK LG Range
LG 27UL850-W 27" 3840x2160 4K 60Hz 5ms FreeSync HDR400 Thin Bezel Adjustable Widescreen LED Gaming Monitor @ £474.95 inc VAT
Display Resolution 4K 3840x2160, Display Size 27", Refresh Rate 60Hz, FreeSync, 5ms Response Time, Contrast Ratio 1000:1, Panel Type IPS, Adjustable, HDR400
Only £474.95 inc VAT.
ORDER NOW
LG 27UL650-W 27" 3840x2160 4K 60Hz HDR400 FreeSync Thin Bezel Adjustable Widescreen LED Gaming Monit @ £439.99 inc VAT
Display Resolution 3840x2160, Display Size 27", Refresh Rate 60, FreeSync, 5ms Response Time, Contrast Ratio 1000:1, Panel Type IPS, Thin Bezel, Adjustable, Flicker Free, VESA DisplayHDR 400
Only £439.99 inc VAT.
ORDER NOW
LG 27UL600-W 27" 3840x2160 4K 60Hz HDR400 FreeSync Thin Bezel Widescreen LED Gaming Monitor @ £399.95 inc VAT
Display Resolution 3840x2160, Display Size 27", Refresh Rate 60Hz, FreeSync, 5ms Response Time, Contrast Ratio 1000:1, Panel Type IPS, VESA DisplayHDR 400, Thin Bezel, HDMI, Display Port, Flicker Free
Only £399.95 inc VAT.
ORDER NOW
LG 24GL600F-B 24" 1920x1080 TN 144Hz 1ms FreeSync Widescreen LED Gaming Monitor @ £189.95 inc VAT
Display Resolution 1920x1080, Display Size 24", Refresh Rate 144Hz, FreeSync, 1ms Response Time, Contrast Ratio 1000:1, Panel Type TN,
Only £189.95 inc VAT.
ORDER NOW
all lg monitors
exclusive to ocuk
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
