** NEW LG MONITORS - INCLUDING 2 EXCLUSIVE TO OCUK!!! **
OcUK Staff
23 Feb 2015
Overclockers UK HQ
Hi all,
I've spent this morning setting up some new LG monitors for pre-order on OCUK. Two of which will be UK exclusives at OCUK!
The two exclusives will be landing at OCUK around the 16th July (27GL850) and 13th August (34GL750). Stock is fairly limited so pre-order soon to guarantee one at launch. Second waves of stock should be around a month after each date.
Check out the exclusives and the other LG monitors added to the range below!
ALL LG MONITORS
EXCLUSIVE TO OCUK
LG 34GL750-B 34" 2560x1080 IPS 144Hz 1ms HDR10 FreeSync/G-Sync Compatible Curved Widescreen LED Gaming Monitor @ £509.99 inc VAT
Display Resolution 2560x1080, Display Size 34", Refresh Rate 144Hz, FreeSync, G-Sync Compatible, Response Time 1ms, Contrast Ratio 1000:1, Panel Type IPS, Curved, HDR10, Height Adjustable
Only £499.99 inc VAT.
ORDER NOW
LG 27GL850-B 27" 2560x1440 NANO IPS 144Hz 1ms FreeSync/G-Sync Compatible Widescreen LED Gaming Monitor @ £449.99 inc VAT
Display Resolution 2560x1440, Display Size 27", Refresh Rate 144Hz, FreeSync, G-Sync Compatible, Response Time 1ms, Contrast Ratio 1000:1, Panel Type IPS, HDR 10
Only £449.99 inc VAT.
ORDER NOW
New to the Overclockers UK LG Range
LG 27UL850-W 27" 3840x2160 4K 60Hz 5ms FreeSync HDR400 Thin Bezel Adjustable Widescreen LED Gaming Monitor @ £474.95 inc VAT
Display Resolution 4K 3840x2160, Display Size 27", Refresh Rate 60Hz, FreeSync, 5ms Response Time, Contrast Ratio 1000:1, Panel Type IPS, Adjustable, HDR400
Only £474.95 inc VAT.
ORDER NOW
LG 27UL650-W 27" 3840x2160 4K 60Hz HDR400 FreeSync Thin Bezel Adjustable Widescreen LED Gaming Monit @ £439.99 inc VAT
Display Resolution 3840x2160, Display Size 27", Refresh Rate 60, FreeSync, 5ms Response Time, Contrast Ratio 1000:1, Panel Type IPS, Thin Bezel, Adjustable, Flicker Free, VESA DisplayHDR 400
Only £439.99 inc VAT.
ORDER NOW
LG 27UL600-W 27" 3840x2160 4K 60Hz HDR400 FreeSync Thin Bezel Widescreen LED Gaming Monitor @ £399.95 inc VAT
Display Resolution 3840x2160, Display Size 27", Refresh Rate 60Hz, FreeSync, 5ms Response Time, Contrast Ratio 1000:1, Panel Type IPS, VESA DisplayHDR 400, Thin Bezel, HDMI, Display Port, Flicker Free
Only £399.95 inc VAT.
ORDER NOW
LG 24GL600F-B 24" 1920x1080 TN 144Hz 1ms FreeSync Widescreen LED Gaming Monitor @ £189.95 inc VAT
Display Resolution 1920x1080, Display Size 24", Refresh Rate 144Hz, FreeSync, 1ms Response Time, Contrast Ratio 1000:1, Panel Type TN,
Only £189.95 inc VAT.
ORDER NOW
15 Sep 2007
Well that's mucked up my plans.... I've been saving 'rainforest' vouchers people have given me for gifts up and got a buyer lined up to buy my old monitor, all especially for the 27GL850 and now it's exclusive :(.
I know you accept amazon payments as a payment option, but that doesn't work with gift vouchers. Wish you sold your gift vouchers on their store as you have a storefront over there, gonna be hard trying to shift £300 vouchers, to a friend. Anyone got any other ideas, I would normally just wack it on my credit card, but it's not a purchase a I can justify without using the gift card balance.
OcUK Staff
OP
23 Feb 2015
Overclockers UK HQ
Just placed my order earlier for the 27GL850, does that mean if stock lands on the 16th I would get it on the 17th?
Yes, as long as you are mainland UK but those dates aren't firm yet.
Once I have a date firmed up I'll post it here :)
I'll ask sales if there is anything they can do but I can't promise anything.
Caporegime
29 Oct 2007
OcUK HQ
Sorry about that but we have no way to accept an Amazon gift vouchers through Amazon pay unfortunately, hopefully that changes in the future as it certainly would be advantageous :)
15 Sep 2007
Thanks, I appreciate you even asking. :)
Hopefully it does, though I understand why they want to lock in vouchers to themselves.
Been looking at converting the vouchers into bitcoin as you accept bitcoin as payment, but the sites that offer the service to exchange and the idea just seems sketchy to me. And the exchange rate given, i'd rather just save up and wait.
144hz dream on hold, back to 60hz peasantry :p
25 Apr 2019
Could you update the product page to say what's included in the box? Curious to know whether I'll need to buy a DP cable.
Nevermind, just misread it.
26 Aug 2010
29 May 2006
The green sticker ruins the LG 27GL850-B 27 monitor. Who wants a bright green stick distracting from the screen? Please tell us that is not on final production or that it can easily be removed.
25 Jan 2006
Birmingham
The 1ms IPS screens are coming I see. Need to see how far the Gsync compatibility goes; if it is as good as a proper Gsync monitor then could be the one to get.
And I'm sure the Gsync sticker comes off no problem.
OcUK Staff
OP
23 Feb 2015
Overclockers UK HQ
Thanks, why would the ruin such a good monitor which such a stupid move. For me that's gone from a must buy to a complete turn off. Same for the LG 34GL750-B 34 the price is far better then I expected but the curve has completely put me off it.
If you blow hot air from it from a hair dryer should come off leaving no residue :)
27GL850-B
can be ordererd from Germany?
It's UK Exclusive to Overclockers UK. Edited the post to reflect it.
29 May 2006
Thank you. Now the question is pre-order or wait for reviews and get the 2nd batch. So do the sensible thing or impulse buy :)
2 Nov 2018
Tempted on the GL850. No huge difference on the specs sheets vs VG270UP so am I missing something obvious. What about the panel commands the extra 100?
