Wait for some reviews testing old chipsets.
If someone bought a cheap AM4 board with a pound shop VRM they can't expect to get the same performance as a high end board / new board, even a 2700X is constrained in low end boards by throttling VRM's and suboptimal memory support etc.
Apart for thermal throttle on cheap VRM's, performance gap will be placebo level. E.g. you'll see it in a bench mark but not when gaming or using productivity apps unless you're timing them with a stop watch.
The mid range Z570 6 layer boards will support better memory overclock than cheaper X570 4 layer and 4 layer B450/X470, no big surprise there. You may need to drop the Dram overclock a couple of hundred Mhz like you always have on cheaper boards vs what a new board will reach. A few hundred Mhz will be placebo levels.
I don't see what all the noise is about, high end boards allow a small margin of extra performacne to be squezed out of the same chip, it's always been this way.
The 3xxx series will still give you IPC increase and standard boost clocks, you may just be few % down on max boost (100hz is ~2%) and a little down in memory OC. No different to all other platforms. It's still a good step up from 2xxx
just to add
I bought 2 x b350 tomahawks aka pound shop vrms
back on release as i needed legacy pci for RME audio cards and a xonar cards both running with the 1700'sBoth running with b die c14 3200 ram.. both builds ran off the bat with 1st rev bios ...
i have since upgraded one of them to a 2700x with an offset of -0.0125v been running fine for 4 months now ..Vrm is cooled by a fan and i still get max 4.35Ghz boosts and 4ghz all core ...
i also tested bench marked the same 2700x with same gpu and ram in a x470 with good quality M&S kind vrms and got same scores and again same boosts ..yes vrms ran cooler but no good to me as i need legacy pci ..yes i could use a converter pcie to pci board in a x470 or B450 but had issues with them in the past ..
All i am saying is that since release these b350 tomahawk boards have been running fine with 8 cores since 2017 ..they have done a lot of audio & video editing work and gaming too ... i did dabble with memory oc got to 3466 with safe settings with the mem calc but was always on the back of my mind if it was going to crash while in a audio session or editing ect so i just leave them set at 3200 c14 ..
i am so tempted to try a 3700x in one of my builds just so pound shop VRM's get some love
so my point is even cheap vrm's work if there cooled correctly
