- 21 Sep 2018
The low core parts are clearly better at single core loads.
But why, is the stock cooler not capable of letting the 3900x run at 4.6 and so it downclocks the cpu to 4.3 to prevent temps from getting too high?
We know the 3900x pulls nearly 100w more power under full load than the 2700x yet they use the same air cooler
On some loads, yes, the temp will dictate how far the cpu will boost. Some boost will be closer to the base clock.After market cooler would be needed for a 12 core for sure.
https://browser.geekbench.com/v4/cpu/13678723
To me the motherboard is the glue holding everything else together. You can't get the best out of your high end components of your motherboard is weak.
