don't be silly - that requires common sense lol
Ouch ?? some people are just impatient and want new shiny ..if AMD state it will be supported then they expect that.. i myself not too fused and agree peeps should wait but try telling that to the peeps i know i am just trying to help them out thats all ..
Just to check a few things, if you use flashback, try the following.
Follow that and you'll have no issues, to many people are skipping steps and causing themselves massive headaches.
- Download the .zipped BIOS from MSI
- Extract file, and then rename it to MSI.ROM, ensure that file extensions are turned on in Windows so you can see the extension change.
- Format any USB pen drive type device to FAT32/NTFS, and then copy the file across, eject the stick to ensure writing has completed.
- Remove old CPU and RAM from the motherboard
- Insert the USB stick into the flashback port on the read I/O
- Turn the system on
- Press the flash back button a few times, then it will go red.
- Wait ~5 minutes.
thx again Journey ..out of interest did you use the bios on the standard mortar b450 page
Version
7B89v17
Release Date
2019-06-24
File Size
10.11 MB
Or the one on the are you ready for ryzen page the b450 mortar Ti E7B89AMS.A7M
- i get what your saying though but i just don't understand why the rush for 1st gen users. it was being said far and wide that the bios updates needed would be slower to surface for the x370 boards as the mb vendors focussed on x570, then x470
