don't be silly - that requires common sense lol
Ouch ?? some people are just impatient and want new shiny ..if AMD state it will be supported then they expect that.. i myself not too fused and agree peeps should wait but try telling that to the peeps i know i am just trying to help them out thats all ..
Just to check a few things, if you use flashback, try the following.
Follow that and you'll have no issues, to many people are skipping steps and causing themselves massive headaches.
- Download the .zipped BIOS from MSI
- Extract file, and then rename it to MSI.ROM, ensure that file extensions are turned on in Windows so you can see the extension change.
- Format any USB pen drive type device to FAT32/NTFS, and then copy the file across, eject the stick to ensure writing has completed.
- Remove old CPU and RAM from the motherboard
- Insert the USB stick into the flashback port on the read I/O
- Turn the system on
- Press the flash back button a few times, then it will go red.
- Wait ~5 minutes.
thx again Journey ..out of interest did you use the bios on the standard mortar b450 page
Version
7B89v17
Release Date
2019-06-24
File Size
10.11 MB
Or the one on the are you ready for ryzen page the b450 mortar Ti E7B89AMS.A7M
