- 26 Oct 2013
- Scotland
spent £1185 for all my new items and not one packet of haribo![]()
If this is true surely there's an employee that needs
Typical, all the AM4 EK blocks are out of stock on OCUK nowOrdered elsewhere for tomorrow though
3600 CL14-15-15-35 1.35v 8GBx2/8GBx4
3200 CL14-14-14-31 1.35v 16GBx2
3600 CL16-16-16-36 1.35v 16GBx2
I suspect we will see our first deliveries end of July and though our current 3200 and 3600 kits work fine these are a little better.
Now the bad news memory prices increased 5% today as did NAND and were hearing it’s just the start but we’re hoping it’s just a blip and things will settle again as we don’t want ram prices exploding again.
There's been talk of the way the heat it output differently from the chiplet design. I doubt they are making one, but I thought it's worth a message before I order one.
I’ve also being working with TeamGroup to get more 8 Pack memory options and this morning Team engineers finally finished their testing and will now start producing under our 8 Pack brand the following that are perfectly suited to Ryzen and also fine in Intel and again use screened Samsung B die and we shall be cheaper than G.Skill on equivalent kits:
order shipped! thanks OCUK @Gibbo
Great news! Any idea on provisional costs? These could be some of the 'go-to' kits amongst enthusiasts on the AM4 platform with Ryzen 3.
I assume the 16GB sticks will be dual rank, and they haven't worked voodoo and got 16GB Single rank DIMMs![]()
guaranteed binned B-Die is exactly what the Ryzen Dr called for haha
Has that had a noticeable impact on overall performance and benchmarks?Nope, sorry Ryzen 3000 isn't fussy at all. Been messing around this morning, and yet to find anything that will not run well, I've got a set of Micron E-die 32GB (16gb x2) sitting at 3600MHz C16, and it will do C15 easily with a slight voltage bump. The era of over priced RAM needed for Zen is over.
Woohoo can't wait but suspect it will be as quick as 2080S and launch a year later for the same price.Big Navi is coming art some point
I'm on the cusp of cancelling my order. Not enough gain from a 2700x to a 3700x/3800x right?
There are two games where there is a decent gain, Tom Raider and Far Cry but generally not much of an improvement between the CPU's.
I cancelled.
I'll wait for next year and see whats what.
I do my best it’s not easy when I’m not even in the UK but I said at the start of this launch OcUk would get the most and generally be first and we have delivered.
definatly back off the volts at 4.1ghz you should be closer to 1.3v or lower if you can, my 3900x was at 4099mhz at 1.42v and hitting over 90 i started overclocking and got 4.35gz at 1.2875v and temps have peaked at 75 degrees which is miles better, (i'm running custom 360mm rad aftermarket watercooling)
That seems like a lot of voltage for a 7nm part, it may be safe but I’d probably be wanting to stay under 1.40v and under 80c for longevity of the part and OC stability. But others can probably advice better!
