There are people on well over 100k on the original clutch![]()
Just confirmed the recall on Monday, with the big service including ac refill for £231. And a Lexus CT200 as a courtesy car.
Good luck
Good price on the service too
I'll be making Alan Partridge Lexi jokes to myself all next week!
They won't get it, then you will just seem creepy.
Thanks mate. Yeah I thought it was decent. The girl who is doing all the booking is really good. So if there's any problems I'm sure she will help me out. And quite a few of the salesmen there have GT86s, so hopefully that means they would have made sure their's were done to a high standard, so mine should too.
Goes a long way when you get on with the staff!In that case I'd imagine it'll be all good thenGoes a long way when you get on with the staff!
Lexus are some of the most comfortable cars tbh. A much nicer ride than the German equivalents.
I noticed yesterday (for sure) that upon reversing, my car was no longer beeping. I can't hear the initial beep when engaging reverse gear either.
Reversing lights are on ok below the boot when engaging reverse.
The issue may have been happening last week too, but I could have been oblivious too it - I remember thinking a couple of times that I couldn't hear them (over the radio) and ended up very close to walls/bollards/cars behind me.
I did have my recall done the week before, so not sure if related. When I picked the car up, the clock had been reset, so wondering if the issue is related to electrics.
I've looked into the owner's manual, but there is no section on the reversing sensor, in particular nothing regarding its fuses, or diagnosis or troubleshooting.
Any advice or suggestions about what I could try, in case there are simple checks, before I ring up my dealership?
Thanks in advance.
P.s. If it matters, car is 2012 manual.
Mine has no beep. I thought it was only the newer models that did.
Do you have parking sensors on your rear number?
Cheers Steeps; will investigate when I'm home. I hadn't been looking behind the carpet. On a side note, can't believe how many loose cables and boxes just hang below the boot lid. I'll have to stick them to the sofft better, or a bag or suitcase could easily catch one.
