- 14 Aug 2018
That's pretty much what I've got plus it is passive so does not add to any noise threshold.A £30 Nvidia GT710 would do the job.
(Just seen others have mentioned the same above)
If you're running a later version of Win10 then absolutely no need to do so and a waste of time. You will just need the motherboard chipset drivers etc. from the manufactures website.Im moving from intel to amd will i have to format my ssd and do a new windows install ?
A proper NAS doesnt run VM's. A proper NAS is a NAS.
But for home use i can see your usage model.
As a note though, that 4-core Ryzen would still be able to run most things you are trying to do pretty well, including transcoding of videos or other CPU heavy tasks, whilst running a few other VM's perfectly fine too.
What sort of workload do you envision to be virtualised?
Cooling down cpu better than overclocking......For anyone interested - live:
From his initial warm up it would seem so.Cooling down cpu better than overclocking......
Unfortunately not. Which is a bit annoying tbh.Does PBO and Ryzen master work if Virtualization is enabled?
Without PBO how do these processors perform? how is gaming performance without PBO?Unfortunately not. Which is a bit annoying tbh.
Perfectly fine.Without PBO how do these processors perform? how is gaming performance without PBO?
I have same 3200CL14 RAM with zero issues at stock and seems fine to run at 3600CL16.. and thats on my 2700X.
I run it at 3200CL14 as Zen+ likes to run faster on the lower latency, as we all know
Cant imagine it not easily doing 3600CL16 on Ryzen 3xxx chips.
Perfectly fine.
I have it turned off on mine and it still boosts up fine.
PBO is Power Boost OVERDRIVE, as in, beyond its advertised boost speeds. You dont need to have it on to get the full performance of the chip.
