I watched it yesterday, as far as I remember it made no difference so I dont know what the issue is.not sure if post up
I know, just saying that the issue does not seem to be based on AGESA (at least in his case) so god knows where the issue is coming from. I am waiting for the 3800X to appear, still rocking a 7700K :/just posting for those that are interested etc - still on 2700 myself![]()
You should check our rain forest "dispatched in 1 to 2 months" lolWhen 3900x ? i See at Box they will got CPU only in middle of August, yesterday was this Tuesday
Apparently 1003AB AGESA is the one that fixes 2 core boost clocks rather than 1003. I have MSI x570 board and the latest BIOS is based on 1003 released 2nd of July.
In the PBO thread a guy with a 3600X+MSI X470 Gaming Plus is getting 125mhz PBO with 1.0.0.3. All this PBO seems to be down to luck if you ask me.aorus have their AB out which is handy, should take to long for MSI .
what i feel for is B450/X470 boards as not the priority . many vendor reps say that that AGESE updates can effect their bios without them being able to test everthing and rely on users feedback
So anybody here with 3700x getting the advertised 4.4Ghz boost on single core? Max I've seen I get is 4.275Ghz which gives me single core R15 score of 205 and R20 single core score of 504. (RAM at 3600Mhz cl16)
The temperatures and voltage on idle is also quite strange it is stable then spike up with a gradual decrease after. Even on load it follows the same profile somewhat stable with many difference instances of spikes that then go down back to average. Very odd behaviour. If the load is uniform why would it spike and then go down gradually, it just looks like software bug to me.
Did we actually get an official AMD response that yes, voltages at 1.5v every 5 seconds is normal and that idle temps of 40-70c is normal and that the processors wont reach their advertised single core boost? Or is it the case that all the motherboard's BIOSes are broken?
IPC testing Ryzen 3000
Well it did in Cinebench, some people seem to think that Cinebench IPC = overall IPC.There's not much in it now but what happened to all the people who claimed the 2xxx series had equal or better IPC at the same clock speed?![]()
