Raspberry Pi - $35 Linux computer
13 Jun 2016
UK
Got my official Pi 4 case in the post today, whilst I wait for the Flirc case to become available!
29 Dec 2002
Watch the temperatures soar when you fire it up in that completely unventilated case :D
You’d hope that they had tested it in the official case, given the bios fix to lower temps, if anything it should be cooler now. Alternatively, buy marshmallows :D
13 Jun 2016
UK
Don't worry, the lid will be coming off :D To be honest, it was more to protect the Pi than anything else as I knew it would only be a matter of time before it got damaged otherwise! For £5, at least it's safe in the plastic home.
Will be running that firmware update for the temps though :D
maj
maj
19 Jul 2010
Durham
For those that really want to cool their Pi 4, take a look at the ICE Tower cooler. Good luck finding a case that works with it fitted though :p
4 Feb 2003
Birmingham
Post if it fit well and such, the Pi 3 version seems to work really well according to youtube videos.
I can confirm the Pi3 version works very well as I have one, the fans are silent and it rarely gets above 40 when running more intensive tasks even in current warmer weather, allegedly they can be a little hit and miss for fit particularly on the bottom face (factions of a mill for a tight fit against the chip) so I imagine that's down to QC at the factory end.
Commissario
16 Oct 2002
In the radio shack
I was a little concerned that when I finally get the Pi4 mounted outside that there's a possibility that fan shim could creep it's way off the board. Admittedly, it's not very likely but as it's only held there by friction, I had two options. Solder a couple of the pins or add a mechanical fixing. I chose the latter as it's easily removable.
It's not going anywhere now :)
13 Jun 2016
UK
Good job! :)
Commissario
16 Oct 2002
In the radio shack
My loft Pi3B has been getting a bit toasty. It's in the official Pi case and has no cooling whatsoever:
So has the 3B+ I have mounted at the top of a 33ft mast in my garden. This one has an Airspy mini attached to it so it's always sitting at about 20% CPU load. It does have a fan though, the one linked in this post.
Neither of them have throttled though so that's good.
29 Apr 2004
Bath
Anyone considered a sandisk high endurance micro sd card for their Pi? My storage was corrupted tonight and I think my current card which is quite old is on the way out so I'd like to replace it with something more resilient.
