3800x shipped!
Dammit. I've pulled trigger too. Got the Aorus Ultra on it's way from a German site as everywhere UK seemed OOS (though seems more have arrived in a few places, oh well). Should have both by the weekend
3800x shipped!
Pretty much the only game where turning off SMT helped fps in GN review was Total War. For others it made no difference and in couple cases actually lowered fpsDoes anybody disable smt? Using a 3700x atm coming from a 4c/4t disabling a 3700x to 8c/8t is still a massive improvement and surely has to be a better gaming experience? If all you do is game you hardly need 16 treads. I seem to be able to overclock at lower volts disabling smt too.
Not unexpected. With Microsoft, not all scheduler improvements turn out to be improvements. Probably if it doesn't see a familiar CCX topology, scheduler goes stupid.I've found the moment you turn off smt, the threads hop like crazy between cores. With SMT the threads stick to a core.
I see well that's not as bad as I thought at least it does get to its advertised speed.Yes, they all will bench CB @ 4.4ghz. The best I have managed is 4.5 on a few of the cores to bench. I'm using the stock cooler currently (new one ordered) and it struggles.
I might try setting the LLC to something a bit beefier also at some point.
My best All core is 4.3 for a run on CB before the temp hits 95. At 95 it all shuts down.
I'm still on the fence with an upgrade. Worth while? Money isn't the issue. I just don't want to do it if there really is no gains in gaming scenarios.
What you think 2700x -> 3800x?
I see from reviews on average it's about 12-16% gains in gaming.
For now.. I'm sticking with what i have in my sig, 2700X is enough for my uses right now.
Zen 2 next year will come soon enough and i bet 7nm+ will be a less buggy/much smoother launch BIOS wise etc.
Just purchased a 1TB Sammy 860 EVO.. i need another SSD more than a CPU upgrade to be perfectly honest![]()
Not advisable with M.2 disks.Posted this previously in the wrong thread but has anyone tried BCLK OC’ing yet?
Worked well for me on the 2700X.
aorus and msi test boards
Yea you right. I should not upgrade the CPU. It's hard tho. I already pressed buy on a 3800x last week and then cancelled.
Reason why i never touched BCLK.. Buildzoid said in a video a while back that it can kill M.2 drives, and they still aint cheap to be honest.
That what warranties are forthey offer you 3 and 5 year warranties for a reason
when u think about how far ssd have come in just last 5 years speed reliability etc I’ve had 5 different ssd drives for my main boot drive alone. It’s not our job to make parts last if u have 3 or 5 year warranty make your parts work as hard as you can
Even if i needed to upgrade, all these BIOS issues would put me right off anyway. I think its best to wait for things to settle at least.
