- 7 Sep 2012
- Lancashire, England
I installed my Ryzen 3600 earlier and I've noticed the stock voltages appear a tad too high... Or is it just me? I've had a little look around the Web and as usual there's some conflicting information.
Basically, my cores can reach up to 1.46v when boosting to 4.2GHz. My chip has no issues reaching its advertised speeds (a problem some people seem to be having). My 3600 appears to run at 3.9GHz when all cores are being used (at 1.375v).
Do these voltages seem normal? I read a comment somewhere on here saying the ryzen 3000 series has a voltage range up to 1.5v and it's nothing to worry about?
My motherboard is the Asrock X470 Taichi with the latest BIOS (L3.43). I'm also using an Alpenfohn Matterhorn cooler. The chip seems to sit between 66-70C when gaming which is a bit higher than my I7 6850k with the same cooler, case and airflow setup (it usually maxed out at around 60C when gaming).
All the BIOS options are left at stock settings. The RAM is running in XMP mode, but sadly it's only DDR4 2666 stuff from my X99 build which I'll be changing soon to something faster.
