Knife Thread
Bought a knife from a local kitchen place shutting down, 30% off. Tried a bunch of different ones and this one has the best feel and balance in my hand.
The one on the left.
Well, I never did get round to buying the carbon knife I looked at a few months ago. However, it was my birthday last week, and my fiancée surprised me with this beautiful VG10 core, 17 layer Damascus gyuto:
Very nice.
I am off to Japan later this year, going to get myself a knife or 2 when i am there. Might even visit Seki (where they make the Samurai swords and now knifes) to check it out.
Guys, I have some amazon gift vouchers and have been deliberating over electric and manual knife sharpeners. But I think I'd like to take the plunge and try my hand at a whetstone. I'm reasonably confident I could keep a fairly consistent angle, and I'd be happy to use an angle guide as well. I don't really want to pay more than say £15 for a double sided stone, and I think I should be looking at a 1000/6000 block? Can anyone recommend me one from these?
https://www.amazon.co.uk/s?k=whetstone+1000+3000&i=kitchen&crid=2YPXSOLFI97TD&sprefix=whetstone,kitchen,192&ref=nb_sb_ss_i_2_9
Very nice.
Off to Japan for the first time time in November and have had Aritsugu recommended by the father-in-law, in the Nishiki market in Kyoto - any experience with them?
I’ve been to Nishiki but I don’t plan to go to Kyoto this time. No doubt walked passed that very shop though.
this is what i'd got
Thanks jpaul. I can't find that 313264 model either on your link or on Amazon. Thing is, there seems to be lots on Amazon around £10 to £15 with tons of great reviews, so I'm kind of confused on how much I need to spend. Is Naniwa better than most? Won't one of the cheap double sided stones do a decent job? How about this one? https://www.amazon.co.uk/BearMoo-Sh...ateway&smid=A16BMBGNHM94J0&sr=8-3-spons&psc=1
I'm not looking for absolute professional razor sharp, especially as my knifes are nothing special and particularly because I value my fingers. I just want to learn how to do it and get a better finish than a standard knife sharpener. And if I get good at sharpening then I could consider investing in better knives.
Yes, I see what you mean. I just looked at loads of other stones, even more expensive ones, and the Naniwa one you linked is bigger than all of them, 24 x 7.19 x 4.8 cm. I guess that's the one to go for? Seems like Naniwa is a well respected brand.
One other thing. I suspect if I look closely at any of my blades edges they'll probably have some damage. If that's the case, should I be looking at a lower coarse grit of around 300/400 or will 1000 take care of damage?
I use a santoku knife mostly. Not only is it a versatile knife - byut the identations help slices fall off (things like carrots that usually get stuck on the sides). You can pick up santoku (or santuko) knives at most supermarkets - give one a try.
Thanks. Relatively easy for me to get to places that will sharpen it I think, so if I do that once a year perhaps a steel is all I need?
Following on from this old reply here, I still haven't sorted out how to look after my Wusthof :( I'm going to take it to the Japanese Knife Co in Soho as it's about 5mins walk from my workplace (let's hope I don't get stopped on the tube for carrying a knife? :confused: ). But I want to buy a honing steel. What's going to be the main difference between for example the Pro Cook ones and the millions of different Wusthof ones? :confused:
So what would everybodys set of choice be at the minute assuming a £200-£250 budget?
I've been looking at Edge of Belgravia after finding some positive reviews, but the amount of choice out there blows my tiny mind. Just after a good all round set that'll last a few years. Mainly meat and veg, doubt we'll ever fillet our own fish.
Anyone got recommendations on a whetstone besides the one mentioned above? :)
A while ago I was watching this YouTube channel where this guy does a ton of knife videos, he even makes them out of like pasta....yes, knife out of pasta.
Anyway, these 2 stones are the one he uses.
https://www.amazon.co.uk/gp/product/B001TPH9CM/ref=ox_sc_saved_title_2?smid=A3I6JEDMMCCBQE&psc=1
https://www.amazon.co.uk/gp/product/B000EBFWY4/ref=ox_sc_saved_title_3?smid=A33E5WOLTPQPO&psc=1
Oof, I meant to put a budget on my above post :p I don't feel like I need to splash £150 on stones right now. It seems a little excessive. I had spotted Naniya as the most respected brand, but also KING which are a lot cheaper. There's a lot of super-cheap ones called BearMoo on Amazon but although they're very well reviewed I suspect they're cheap for a a reason. Aiming to spend £40 on a combination stone to get me going, ideally...
Has anyone tried claiming on Wusthof's warranty?
I have a set of ten year old Le Cordon Bleu knives and the handles are starting to disintegrate.
They're great blades otherwise and I want to keep them. Fully forged with riveted handles so should be repairable I assume?
No, but I'd be very interested to hear how you get on. I recently bought my first of theirs and it would be nice to know that the warranty has legs!
Finally sorted after a little back and forth.
New set of Classic knives (some with half bolster as requested) appeared today:
After an investigation by Head Office, they conceded that the rivets had been over-tightened causing the handles to crack. Brand new set after 11 years of use...not bad!
