I'll have another go tomorrow then. The instructions are in the zip archive you download?
Zeed is correct you need to import the exported timmings for your RAM then calculate or you will get some crazy low timings that won't boot. Use Thaiphoon Burner to export timmings:
http://www.softnology.biz/
I've managed to get 3800MHz (IF 1900MHZ) 16-16-16-16-36-48-304 1T so far @1.4v with 8-Pack RAM - 65ns latencey
As already mentioned by other members use Karhu RAM Test for stability.
