AMD Zen 2 (Ryzen 3000) - *** NO COMPETITOR HINTING ***
Caporegime
17 Mar 2012
ARC-L1, Stanton System
same 93%
@Operation well as i said nothing till next week and we will loose PCIE 4.0 support on x370 and x470 after new bios hits
AMD made changes in 1.0.0.3ABB and removed the support souch a fantastic pro consumer move init @humbug
https://www.guru3d.com/news-story/g...n-all-amd-motherboards-that-are-not-x570.html
What what????? :p
@humbug latest bios out for your motherboard chap! AGESA 1.0.0.3ABB - You might get your memory higher without audio corruption now!
https://www.asrock.com/MB/AMD/AB350 Pro4/index.asp#BIOShttps://www.asrock.com/MB/AMD/AB350 Pro4/index.asp#BIOS
DAH! just released, thank you :)
ljt
ljt
28 Dec 2002
West Midlands, UK
thats where manual comes in :)
Yeah, I've just managed to get my 81% teamgroup 3200 cl16 b-die to 3600 (16-16-16-16-36-52-345) at over 400% HCI, so hopefully that will be stable enough. Currently gives me about 68.3ns on aida. That's plenty fast enough for me I think as I'm not really into tinkering.
Permabanned
15 Oct 2011
Nottingham Carlton
Thats nice TRY tRFC 312 with those timings if ya want :) And what volts on ddr are You at ??
18 May 2010
London
Seems my ram is happy enough to post, boot windows and stress test at 15 15 15 15 35 @ 3600MHz @ 1.35v.
That might be the best I can get with this ram at 3600MHz with lowest timings.
I'm gonna give it a quick 100% pass with HCI then game on it and see how it goes.
Seems to be an issue with this. Although I set 15 for the CL it is actually setting it to 16.
21 Jun 2018
Ashton
Okay so new motherboard running, with my ram installed. Managed 3600 cl14 with IF 1800.
That gets me a 70ns latency...
But my peak core speed is low, at 4.1ghz multi and 4.25ghz single. How do i improve that? I
Install the new chipset driver, latest BIOS, and it should honestly do it on its own. What CPU is it?
30 Jun 2004
Dublin
I've used DRAM calc to tighten my timings (x570 taichi, 3800x 8pack 4000mhz ram)
It boots, but then i get errors in membench. I'm a complete noob when it comes to ram timings, i'd like it as fast as possible stable, whats the next step for me, which timings do i slacken and to what?
XMP takes the infinity fabic out of 1:1 (mine wont go over 1800mhz anyway)
21 Jun 2018
Ashton
Did you update the BIOS? Because early Taichi BIOS did not allow to overclock IF due to a bug. 1.70A should solve it.
