Caporegime
- 1 Dec 2010
- Welling, London
Well please feel free to explainClosed mind much?
I have not idea what it means. It's a freesync monitor so I wouldn't assume that.I can only assume G-Sync compatible stuff.
Update include:
1. Multi-language option optimized.
2. Optimizations for latest games.
How do you like the monitor so far?
I'm having a blast wiith it in twitch shooters and I'm still on balance overdrive. Stop using Fast do to AMD's use of Radeon Anti Lag.
I did have trouble using the provided DP as it wouldn't upscale to 4k properly. I had to get a Vesa certified DP and everything started working correctly. Biggest difference was using Super Resolution. Now I see a difference. With the new cable I can see it's not Sharpening. With cable provided with the monitor it looks like sharpening when used. Not sure why that is.
My only concern is the fact that you cannot select hertz within the OSD. You have to go through win10 to do it. Would be nice to change it through OSD. Any monitors that actually do that?
Yeah, i'm really liking it so far. Glow and bleed isn't an issue. Im not saying that there isn't any, there probably is, but with it calibrated properly it's not a problem when the brightness is cranked down. No dead pixels and panel uniformity looks fine, not perfect, but it's fine. Manufacturer date was May 2019, so fairly recent.
Calibrated at 10Bit and 8Bit. Currently using 10Bit at 120Hz.
Gamma i've turned off, it tracks closer than Gamma 3 for some reason?
Other than that it's fine. Was a bit weary of spending that much on a monitor when all I've seen is people complain about QC, but after the MSI nightmare i just though meh!
Yeah, in order to keep 10bit you have to lower it to 120hz.
You turned Gamma off? I just tried that myself and there is very little difference??? Is that working right?
Do you have an Radeon or Geforce card?
Well in that case it will be the default setting for me moving forward. Although I would prefer a term other then Off though.Yeah. It tracks closer to the 2.2 Curve at the lower brightness. Gamma 3 tracks closer to 2.3/2.4
I've got a 1070 Strix
If you're ordering an ips panel,then clearly the buyer cares about image quality.240hz panels are a very niche market.For a start not everyone prioritises imagage fidelity over fps, lots of people see the attraction of utter smoothness (esp when combined with a blur reduction mode).
Not everyone is the same, hence their being quite a healthy market for these 240hz panels.
If you want a proper calibration you need to get a device to do it. Each panel is different so no to settings will be the same. It's just a rough ballpark guide
LOOOOOOOOOOLMost minor of complaints I know, but has anyone else’s Auros badge on the front come unstuck? I think I’m gonna have to glue mine on.
Aren't 240Hz monitors Tn panels? I've not seen many IPS versions.
Sure-sure. I have a Sypder that can do it. But for me I've not used Adobe apps in a long time where I would need to do that though. I still cringe using their "online service now" but hey they got me to kick the habit. LOL. I digress though...
Do you really need to calibrate your monitor for general use?
Probably not if you've never seen a calibrated screen but if you have... Everything else always looks yucky once you've been accustomed to a calibrated picture. From blue-ish/magenta tint to horrid sunburnt/yellow/brownish tones.
Then most people have gotten so used to high vibrance that they freak out to natural colour because they think it now looks dull.
Did you try rubbing alcohol to clean it and put it back on yet?Most minor of complaints I know, but has anyone else’s Auros badge on the front come unstuck? I think I’m gonna have to glue mine on.
You might as well give the spyder a go with DisplayCal. Nothing to lose really, plus you'll be able to see output reports/verification reports etc.
