On the screenshot? 3800Mhz 1900 FCLK and 101 BCLKWhich setting was it in the end?
I have this mr öpeth, in metro and apex after While the game freezes but not the pc, is that what happens to you?So if you say it's different for every board. Then I'm clueless what to do to stop the freezing. Leave VDDG on auto and up SOC a little bit?
Basically I can play for maybe 4hrs before experiencing a freeze.
Dram volts are 1.35v. I left them there because the 3600MHz CL16 Darkkpro ram which Gibbo says is the same bin as the 3200MHz CL14 kit I have also runs a 1.35v.
Could the issue be neither VDDG or SOC voltage but dram voltage?
(I can pass 400% HCI with current settings.)
Sorry, what I meant was where was the BCLK setting?On the screenshot? 3800Mhz 1900 FCLK and 101 BCLK
Ohh in the BIOS change the Overlock Mode to Manual, and then you have to select a range between 100-200Mhz. Thats the BCLK.Sorry, what I meant was where was the BCLK setting?
Ah, so it was the strangely named "APU/PCIe SRC Frequency (MHz)"?Ohh in the BIOS change the Overlock Mode to Manual, and then you have to select a range between 100-200Mhz. Thats the BCLK.
YeahAh, so it was the strangely named "APU/PCIe SRC Frequency (MHz)"?
There is no way that chip is running all core 4.5Ghz and staying at 53C. Unless he is running one CCX 4.5 and the other one very low.
Well for my mates HTC vive gotten 3600+ x570 elite says much better than the 4770k that burned down![]()
3600 and a B450M board or a cheaper x470 i'd say.![]()
Thanks guys, will check them out.
Not a chance with 1.308 volts but then again does not say its even CB20 stable
I missed that cause was listening ye.Technically he's not done that correctly though has he?. He hasn't imported his kits SPD into DRAM calculator first to see his current memory IC quality.
I have B-Die memory but it won't work on V1 timings as that assumes a 93% IC quality, where as mine is only 81%
