Caporegime
- 18 Oct 2002
I gather Nik is on hols atm.
Finally set mine all up, and got a few hours of gaming. A small amount of ips glow, nowhere near as bad as my old UH2515H.
A problem I did run into though was not being able to access my BIOS, the screen would only display input once windows had booted. So if anyone is having a similar issue and is running an Nvidia card, I had to update my 1070's Display Port firmware from here - https://www.nvidia.com/object/nv-uefi-update-x64.html . Not sure how you would do it on AMD or whether it would even be an issue, but hopefully can save someone time in the future.
Thanks Uaon. Sounds very tasty indeed. 6 weeks wait for the next batch Come on LG! Shame about the stand & mounting, but great to hear those positives
I tried the stand and it wasn't the greatest, the worst being that I couldn't get it low enough, my monitor arm was close just needed to shave off 3mm on top side both left and right, works fine now. The important thing is the panel is good,I have mine also hooked up to a monitor arm and there was no issue with spacing on my mount, or need to grind it. Can't speak of the stand quality though as it never left the box
yes normally. maybe i will upload it earlier once i've done the calibration@Baddass When do you usually upload icc profiles? Is it when the review goes up?
Thanks
I'd really appreciate that. What's your initial impressions on colour accuracy out of the box? I was finding that the default settings on gamer 1 had a warm tint, but gamer 2 seemed far more neutral.yes normally. maybe i will upload it earlier once i've done the calibration
The 27GL850 has arrived with me now for testing and full review at TFTCentral. For those who were worried earlier, the small NVIDIA G-sync logo in the bottom left hand corner is an easily removed sticker You can run full 2560 x 1440 at 144Hz and 10-bit colour depth without issue. You may also want to disable the Smart energy saving feature in the general section of the OSD menu to avoid occasional changes to screen brightness
usually within a couple of weeksthis is the one I have my eye on, really want to order ASAP so I can join the queue awesome that you are reviewing it!! how long do you usually take to review products? or is this a "how long is a piece of string" situation?
If you change to gamer 2 mode, i would recommend lowering the black eQualizer back to 50, as the default setting it has crushes contrast ratio quite a bit from what i've seen so far - unless you specifically want that black eQualizer setting like that for certain gaming of courseI'd really appreciate that. What's your initial impressions on colour accuracy out of the box? I was finding that the default settings on gamer 1 had a warm tint, but gamer 2 seemed far more neutral.
On my unit the gamer 1 default mode was a bit too cool around 7000k. That's assuming you've not changed anything else like colour temp or RGB settings.I'd really appreciate that. What's your initial impressions on colour accuracy out of the box? I was finding that the default settings on gamer 1 had a warm tint, but gamer 2 seemed far more neutral.
I can't possibly say at this stage having only just received the screen today. Testing is under way, but you'll need to hang on for the review i'm afraid@Baddass in your early opinion is it the best ips 1440p gaming monitor on the market atm?
