SpecsI've finially finished my build other than waiting on some Trident Z Royal stuff from the US.
This is Project Water: 4.0
Specs
How good are those rads compared to the thin ek and xspc ones?Asus Maxiumus XI Extreme
32GB G.Skill 4266 C19 (Currently 4000MHz C17) , which is being swapped out for a 4266 C17 kit I have on route.
9900K @ 5.2GHz - I can run it up to 5.4GHz i'd rather a lower voltage.
EK Velocity CPU Block
Samsung 970 Pro 1TB
Samsung 970 EVO 2TB
EVGA 2080Ti FTW3 + EVGA Hyrdo Block
EVGA Nu Audio
Seasonic Prime 1200W Platinium + CableMod Pro Carbon Cables
Hardware Labs 360 GTS
Singularity Computers Pump (DDC) & Res
Singularity Computers Tubing 16mm
EK DDC
Noise Blocker Fans
Loads of Bitspower Fittings
Phanteks Evolv X
I think that's everything.![]()
What’s your max temps, realbench and gaming?I have never used XSPC ones so I can't comment. However, the EK SE ones are pure garbage and they will out perform the PE series rads of the same size.
As I had a EK PE in the build before, as was waiting on a GTS.
Is that realbench or gaming?60/70c on the CPU & 40c on the GPU.
That makes me feel a little better as that what mine sits at in gaming, just doing an occt medium dataset run and my temps are around the mid 60s, I’m just debating whether to put a 3rd 360 rad I have into my loopGaming. Prime 95 (26.6) tends to sit 80 maybe 90's on small FFT's but thats a bit extreme.
Having read this thread for many years in envy of wanting a custom loop, I finally have my own. Been up and running for a few weeks now with no problems.
AMD 3900x @ 4.35Ghz - EKWB Velocity Block
EVGA 1080 FTW - EKWB Nickel Block
EKWB X-RES 140 Pump/Res (250 Tube)
2X HW Labs Black Ice Nemesis 360 GTS Rads
Corsair ML120 Fans
Barrow 16mm PETG tubes and fittings
Fractal Design Define S2 Case
Looks good! Soft tube? I did hard tube and my god it was a nightmare. Especially upgrading parts!
I've gone a bit OTT in lightroom it doesn't look this harsh IRL(Just cleaned and refilled it hence all the bubbles)
Ryzen 7 3700X
AORUS GeForce GTX 1080 Ti Waterforce WB Xtreme Edition
16GB G.Skill 3600Mhz
Gigabyte X470 AORUS GAMING 7 WIFI
Various M.2 and SSDs
All EK blocks, fittings, res, pump etc
I have the same case and am looking to go full custom loop, though probably just do the CPU only 1st. Which radiator did you use for the side one? A thinner 360mm I assume?
Also, any clearer pics of how you ran the tubing around the back and how they route into the rads?
Cheers
Soo radiator wise I've got 2x EK-CoolStream PE 360 (38mm thick) top and side, PE 240mm on the base.
The route is pump/res > 240mm rad > out through the rear of the case via bottom cut out > QDC for draining > 360mm rad > through to the front of the case via top cut out > 360mm rad > monoblock > GPU block > pump/res
This QDC fitting has literally mm of space between the side panel but works effectively for the drain!
