Then your bot is wrong.
1700 @140
3700x @ 330
I very much doubt it. It found 7 3700X chips for a lot less than that too.
1700 @140
3700x @ 330
In stock?
I dont think Intel will even catch up in 2021... By that point AMD are going to be on 5nm.
2019 - 7nm
2020 - 7nm+
2021 - 5nm
Unless Intel make a massive leap, but by the looks of things I dont think thats happening.
I agree. If Intel say 2021 we can take that a products shipping in sometime of 2022 and those might only match what AMD have currently.
Nah, we're not getting any meaningful clock speed bumps any more, the smaller processes just don't allow for it. That puts more emphasis on improving IPC and reducing latency. Server core counts will continue to increase, but I think 16 will be the maximum on desktop for a good couple of years (more cores for productivity is the domain of HEDT/workstation systems). But you saying 2023 is a good couple of years away, so you never know.Yeah or sure. I just cant fathom how this is like a new beginning... Core counts/IPC/clock speeds are only going to get even crazier at this point. Could even get 24 cores in mainstream desktops by 2023 I think.
Then there is talk of 4-way SMT coming with Zen 3 next year, so Intel better be targeting Zen 4 otherwise they're going to be way behind. Can Jim Keller beat his own designs?
If 4-way SMT is real, I'd expect 8-core/32-thread CPUs from AMD.
I also think there won't be 24-core/48-thread MSDT CPUs in 2023.
That would be pretty insane to see an 8 core with 32 threads though. But then again would a 8c/32t perform as well as a 16c/32t? I dont think it will
If AMD do go 4-way SMT with Zen 3, it'll be on EPYC Milan and possibly Threadripper
If AMD do go 4-way SMT with Zen 3, it'll be on EPYC Milan and possibly Threadripper. Ryzen 4000 will probably only get 3-way SMT, assuming it's possible to "disable" a thread during binning like you can with a core. And even then that'll be for bragging rights, marketing and "pushing the technology envelope".
2019 - 7nm
2020 - 7nm+
2021 - 5nm
Unlikely. However it may give significant gains over 8c/16t, depending on workload. If the existing threads are hanging around for data from memory or even higher levels of cache, other threads can be executing. I'm pretty sure 4-way SMT has been done on POWER or SPARC before...
Yeah thats a good point tbf. I have ni problemt seeing them on HEDT and server chips, and the mainstream chips will just be regular 2 threads per core. It'll also be better for AMD as there are more distinctions between the EPYC/Threadripper and mainstream chips, whereas atm its just core count. And even then the mainstream chips are close to HEDT chips
IBM's Blue Gene/Q has 4-way SMT, Intel Xeon Phi has 4-way SMT.
Except that the top "mainstream" part is 12-core/24-thread, while the top HEDT part is 32-core/64-thread.
I don't see how the MSDT chips are close to the HEDT chips. Every year, the gap becomes larger and larger.
The real top mainstream part is 8-core - both i9-9900K and Ryzen 7 3700X/3800X.
Heck why not just bring out a special edition and add HEDT features and a x590 mobo and be done with it
As of today the top main steam chip is 12cores and 24 threads and amd do have 16 cores 32 threads.
