- 8 Jun 2018
https://www.pcworld.com/article/3438836/sapphire-nitro-radeon-rx-5700-xt-review.html
https://www.bit-tech.net/reviews/tech/graphics/sapphire-radeon-rx-5700-xt-nitro-review/6/
https://hexus.net/tech/reviews/graphics/134177-sapphire-radeon-rx-5700-xt-nitro/
https://www.tweaktown.com/reviews/9185/sapphire-radeon-rx-5700-xt-nitro-oc-review/index.html
https://pcper.com/2019/09/sapphire-nitro-radeon-rx-5700-xt-review/
https://www.kitguru.net/components/leo-waldock/sapphire-rx-5700-xt-nitro-review/
https://www.igorslab.media/en/sapph...th-less-weight-and-the-best-navi-card-so-far/
https://www.sweclockers.com/test/28149-sapphire-radeon-rx-5700-xt-nitro-och-rx-5700-xt-pulse
https://www.computerbase.de/2019-09/sapphire-radeon-rx-5700-xt-nitro-plus-test/
https://nl.hardware.info/artikel/95...t-nitro+-review-de-extreemste-navi-videokaart
Between the Nitro and the Red Devil the Nitro is faster. However, consumes more power using the performance profile. You can use the silent profile and get RD results at a lower power curve.
The 1st feature is Nitro is Trixx Boost.
Which allows you to reduce 4K/1440p/Hi res resolution to a slightly lower resolution. Then you can select that resolution in-game. You can still enable RIS to sharpen as needed and still get a pretty big boost in frame rates. So far the boost puts the Nitro in the 2080s area.
The 2nd feature is the Triple Bios Switch.
Power
Silent
Software: Trixx Software lets you switch between Power and Silence. You still reboot the PC.
The 3rd feature is the ability to replace each fan with 1 screw.
You can buy RGB fans separately from Sapphire if you like.
https://i.~ibb.co~/ZKjcy6d/trixx-d2-100810939-large.jpg
https://i.~ibb.co~/Mc2XScT/trixx-grw-100810941-large.jpg
https://i.~ibb.co~/Fg5zTwL/trixx-fcnd-100810940-large.jpg
https://i.~ibb.co~/n8DJhn6/F1-2019-FPS-2560x1440-Ultra-TAA-2.png
https://i.~ibb.co~/jgSgmWS/Far-Cry-5-FPS-2560x1440-High-2.png
https://i.~ibb.co~/khhN9zM/Metro-Exodus-FPS-2560x1440-High-RTX-Off-Hairworks-Off-2.png
https://i.~ibb.co~/v1NVq2V/Shadow-of-the-Tomb-Raider-FPS-2560x1440-DX12-High-2.png
https://i.~ibb.co~/3vCSNsf/The-Division-2-FPS-2560x1440-DX12-4x-MSAA-High-2.png
https://i.~ibb.co~/55qLKzc/nitrovs-PCpt1.jpg
https://i.~ibb.co~/L6CgpKS/NItro-1.jpg
Who's getting a Nitro?
It's still rumored that a Toxic version is on the way that will have 10-1 power phases just like the Red Devil. Currently the Nitro is power phases is 8-1.
OEM Blower style cards are 7 phases. So think about this when you decide to get it with the intent to water cool it.
