It doesn't have three. The third setting is simply the one that allows you to choose either the first or the second vBIOS using the software. So you either manually set first or second vBIOS using the switch, or you set the switch to the third and then change as you like through the software.
Looks like a great card with a great cooler and nice to see 3 year warranty instead of the 2 on the Pulse.
So Steve at GN benchmarked it like it had 3 then. Steve being sloppy? That doesnt happen much
Somebody also pointed it out in his comments section.
Hi, Kit Guru mentions the third bios switch at 9:44 He called it the software mode, In the software itself you get to choose between two, the primary & secondary bios.
Maybe i skipped past that bit then, my bad
