Well, possession is only an issue with dragons so probably not worth prioritising unless you know you'll be meeting a lot of them!
Well, ghost can posses a pawn as well, although it is easier to break them out from that if it happens. But since I can't decide as to what clothing to wear it be some dragon hunting for some time so even a little possession protection will be better then none !
This is all personal preference, tbh. I prefer comestion to ingle because I find it more reliable. Either is fine. Seism is okay too for a bigger hitter, I prefer gicel for the same role as it has better range and a way of walloping dragon hearts (or so it seems).
Fulmination chains to allies in range, so your whole party can have it on when a sorceror casts it.
It's alright, don't mind suggestions to see how things works out. You right about the Gicel though, since it is ice based it does hurt a dragon more since they weak against ice. And thanks for the confirmation on Fulmination, I'll take the Immolation and have a try with it all.
I found your pawn and took her on a run of the final wing of BBI. No idea how many RCs you'll earn, but I had her as my only hired pawn. We did kill a firedrake, a frostwyrm, a cursed dragon, a condemned gorecyclops, a living armour, several standard gorecyclopes and about a dozen other mobs, so hopefully quite a few!
I did have to revive her a bit, but that was to be expected. She did cast fulmination on me, though, so I then went climbing all over the frostwyrm with immolation on, so that was a bonus! (I had to fire off and then set off an explosive rivet just in time as she was about to get possessed, though)
Nice run, hopefully she got some more experience on those mobs, if not already from others. Have you released her though ?? I just slept in an inn and did not get a message that someone had been renting her ?
