Ballistix Sport LT Overclocking
1900 is an overclocked infinity fabric. Not all chips can do it
Before you overclock the ram, it's imperative you find out what the max infinity fabric speed your chip can run
okay what voltages do you need to run that sort of IF? I left everything on auto apart from RAM voltage i put to 1.4V
i heard 3733 is the best though and 3600 the compromise. therefore isn't going to 3800 a waste of time if you can get tighter timings on 3600?
I'm running 1.1v soc, 1.05v vddp and 1.05v vddg, can run it lower of course, but CBA to tweak anymore.
3800 at 1:1 mode is obvs better than 3733 1:1 mode.
But if you don't manually set 3800 1:1, then 3800 will run at 1:2 mode which is then obvs slower than 3733 at 1:1 mode
i put soc to 1.125v
ram to 1.4v
running xmp profile for 3200mhz at 3600mhz @ 1:1 with 69.2ns latency now.
i think that is fine. not going to tweak further to gain 2-3 ns.
To be honest, If this is stable, I'll maybe just keep these settings
SOC 1.1V
DOCP enabled
DDR voltage set to 1.4V
VTT set to 0.7V
Maybe this will help, it worked for me.
tCL = low as possible
tRCDRD = low as possible
tRCDWR = low as possible
tRP = low as possible
tRAS = tRCD + CL. Otherwise, approximately equal to tRCD + 2×CL.
tRC = tRP + tRAS
Next two really effect performance
tRRD_S = 4 is best or low as possible
tRRD_L = 7,8,9 try to get as low as you can
tFLAW = 4 * tRRDS larger the more stable
tWTS_S = 4 is best or low as possible
tWTR_L = 7,8,9 try to get as low as you can
tWR = 10 (min value, 12 works well too)
tMAW.MAC = 0 (auto only can't change)
TrdrdScL = 5 (can be 4 or 5) lower better
TwrwrScL = 5 (can be 4 or 5) lower better
Really effect performance
tRFC = 280 (tRFC = 8*tRC or 8*tRC + 8)lower better, aim for as close to 270 as you can.
tRFC 2 = tRFC / 1.346, auto works too
tRFC 4 = tRFC 2 / 1.625, auto works too
tCWL = tCL or tCL -1
tRTP = min of 4, tRTP as low as possible
Trdwr = lower better
tRDWR: these timings directly impact AVX. The tighter they are, the hotter AVX is. The looser they are, the cooler AVX is.
Get as low as possible but I have no idea what these do.
TwrwrSC = 1 (min value)
TwrwrSd = 2 (min value)
TwrwrDd = 2 (min value)
TrdrdSc = 1 (min value)
TrdrdSd = 2 (min value)
TrdrdDd = 2 (min value)
So 3% faster than me, but I have 3600x what is your boost speed? I'm 4.4ghz on single core.
Tbh I'm happy with it. I honestly can't be bothered removing my cmos battery any more it's a PITA every time it fails to boot.
4.4 as well.
What board you got? I just use the bios reset pin when it failed before.
See if your's has one.
Use a reset\power switch :rolleyes: i have it permanently connected.
You are a man of means though.
I don't have crap like that lying about.
Anyway it's going to make zero difference to me in the real world.
I might have another go tomorrow. But I reckon I'm just going to drop soc voltage to 1.1v and be content with what I have done. Its an extra 5% performance. If I feel I ever need that extra 3% I will likely be upgrading to the 4600x.
