The remedy was worth a lot more than £20.No as I don't have time to waste chasing after £20 of paste.
We are very sorry that some of you experienced this and we will try our best to compensate your personal cases.
In general if you experience any of the problems described in this thread don't hesitate to contact us directly: [email protected] and we will figure something out for you.
TG-Support
Hi jansimek,
these kind of "scratches" are normal and will happen with any high end paste which uses metal oxides as base materials (especially aluminium oxide). No matter how small you grind the particles in the end aluminium oxide is much harder than copper or the nickel layer and if you have a cooler like NH-D15 with a polished surface you will always see this kind of result. You would even see the same if you use toothpaste (which usually contains zinc oxide).
This is far from what we considered the issue from last year.
Best Regards
Similar as the others. As I said before: We will try our best to work out solutions for those who have this kind of problem.Arctic Silver AS5, Noctua NT-H2, Gelid GC-1 and GC-Extreme all use metal oxides. That's based on a 5-minute Google session.
Metal oxide crystals are probably the most common method of producing high performance paste (i.e. not just silicone grease) because you can produce different shapes and sizes of crystals. The different sizes can be selected to fit in imperfections between the mating surfaces. That's exactly the point of thermal paste.
Heatsink surface damage has happened ever since enthusiasts started needlessly demanding mirror finishes. Beyond a certain point the smoothness of the surface is much less relevant than the flatness of the mating surfaces.
In your case you would clearly receive more compensation than just a pasteSimilar as the others. As I said before: We will try our best to work out solutions for those who have this kind of problem.
Please don't hesitate to contact our support but please include pictures and a receipt of when and where you bought the paste so we can track it back. [email protected]
As for everything that is sold through Caseking or OCUK I can say that all products in their sales channels are much younger and for sure won't have these issues. Again, this was from early 2018.
What does it matter if you get scratches in a laptop? Surely you won't be reusing the CPU or heatsink, or selling parts?Well, my temps haven't held, so it looks like I am dismantling the laptop this weekend and hoping for the best (that being that one of my thermal pads is just a bit too thick and impacting cpu/heatsink contact). Praying for no scratches.
Just come across this thread, I have just bought some of this paste, thank god I seen this first before using it. Straight into the trash, cheers OP.
I'd be tempted to squeeze a small amount out and rub it between your fingers to check to see if it feels smooth before binning the lot.
Apparently it was only one batch. They're not going to completely halt production for that. The seem to have had a positive response to customer concerns so it would've probably been okay.
