Straight and central, is this OK jumper?
Parking pole...
Those shut lines are appalling and the doors aren't the same colour as the wing. Shed Level 100. Keep up the good work
My steel wheels on my alto were black underneath the silver trims, but once the trims came off they were sprayed blaze orange.You probably had black wheels and now don't want to admit it
Looks like they've been curbed all the way round the edge as wellEven mine?
That's all the frame damage from being so stupidly low
Parking pole...
Even mine?
I told you, I broke it!!
Even mine?
It is no example of perfection that is for sure, but it was cheap, and so far has been faultless. Driven 1000 miles, not used or leaked a drop of anything, drives pulls and shifts smoothly.
Positives:
- No rust/rot
- Mechanically sound
That's progress for AcmeHmmm
- Vehicle structure is corroded but structural rigidity is not significantly reduced (6.1.1 (c) (i))
- Vehicle structure is deformed but structural rigidity is not significantly reduced underneath - been run too low
