Standard = Quality on nVidia, Performance = Performance and High = High Quality. AFAIK AMD doesn't have the same equivalent option as High Performance on nVidia. If there was any significant difference in it one or the other company wouldn't hesitate to take the other to task as it would be a huge PR win.
People use those options?
I have an nVidia discrete and an AMD 2400G in my system so I could give it a try. I already have a personal impression from these that the AMD gives a crisper picture on 2d/desktop type environments. Taking screenshots wouldn't work, but I might be able to setup a dSLR on a tripod and set the same exposure for comparative pictures.
Can anyone who has both Radeon and GeForce systems compare the text fonts in internet articles and post impressions here?
Still gonna depemd on rhe viewers gpu brand, isnt it?
As @Donnie Fisher said, is bit difficult to take representative sample on both my laptop (1060) and pc (5700XT)
Placebo?
I never noticed any difference
	Doesn't the image shot and freeze the quality of the text font at the time of its original display, so everyone should clearly see the differences?
I will also try but later because my old machine with a GeForce went again to sleep in the wardrobe...
Ok, for now:
Ryzen 5 2500U with Vega 8 and Radeon RX 560X.
Text sample with PNG file format, 1920x1080, 100% Recommended scaling in the Display Settings -> Scaling and Layout | Google Chrome Page Zoom set to 110%:
Text taken from there: https://www.techpowerup.com/review/flashing-amd-radeon-rx-5700-with-xt-bios-performance-guide/
	Right, having another look at this. Below is a comparison picture between my AMD and nVidia cards.
Source is a Word template document. Standard black text on white background. TV is a Sony 43" 4k effort. Nothing changed between the shots ... not even the mouse was moved.
Photos and images were done by the following method:
- Canon 80D 50mm F1.4 sat on tripod in front of screen. ( 1/50 , f9.0, ISO400 ) pictures saved to RAW.
 - Autofocused first, then turned to manual focus so that the focal point wouldn't change between shots.
 - Shutter on timer so my hands were't touching the camera at the time of shot.
- Picture taken from AMD source, swapped hdmi cable to GPU, picture then taken from nVidia source.
 - Time difference between shots - 15 seconds on overcast day, so ambient light unchanged between shots too.
 - Image files taken into Canon DPP.
 - RAW files exported with no adjustments into 32bit TIFF.
 - Tiff's overlayed in Affinity Photo to ensure matched up OK (They were 1 pixel out between the RAW files).
 - Same section cropped and copied into the photo below.
Picture as below. nVidia on top. AMD below. Picture is 100% zoom ... there has been no image size adjustments to get to this point.
Is there a difference ? Yes, there is.
If you look at 9 o'clock area of the insides of letters as arrowed below: (pic was zoomed to 200% of original)
You can see that there is the AMD source is making the leading edge of the change from the black to white a bit sharper, and that this sort of change is consistent across most of the leading edges.
Another are you would be the vertical sections of the letter 'u', where the nVidia's letter seems ever so slightly heavier compared to the AMD one.
Like I say, its very very subtle, but these little differences do seem to make an impression when you use the screen as a whole. The AMD is just that little bit crisper and sharper with text.
Edit:
Coming at this fresh again today, I still notice the difference in text - even just browsing the BBC website. The AMD is a cleaner feeling image. Its bugging me now as most of my use of the computer is text based, and its making me wonder whether to change to an AMD card. ( even though I may lose some performance in games which I rarely play )
You can sometimes see small differences on screenshots, but you need to see it in person really. Using the same monitor.
Going from Nvidia to AMD I noticed it straight away. Colours seem stronger on AMD and textures a bit sharper. I've switched between Nvidia and AMD cards a number of times and the difference is there. You can tweak geforce settings but you can't quite get it to match, if you try to add vibrance for stronger colours you get banding which doesn't appear on AMD.
