- 8 Jun 2018
Yes, those PCIe connectors should be exactly the same as the ones on the end.So 2+6 pin two separate ones?
Take another pic once the other connectors are connected to the video card. The connectors on the end should be dangling free below the card.Oh okay I'll have a look now
Have a gander at Cooler Master Website:I've got three connectors dangling from the two separated cables going in the PSU?
@Kevin Matthews
I don't want to steer you wrong mate. Look at the manual for the PSU.
However, the 2nd pic looks to be the end that goes inside the video card. But again check the manual.
The 2 pins bent downward should belong to the PCI-E 6 pin facing the camera. That "thrid"Manual ain't helpful at all, so using one cable should be enough?
PCIe right?
PCIe right?
But yeah that looks right to me. 2 separate PCIe connectors from 2 pcie cables connected to the video card. Just double check to make sure that the other end of those cables are in the right slots/plugs/connectors for the psu.
No problem mate.Yeah anyway I could try that I could test or try like gpu pwr or anything etc or anything to look out for mate? Sorry for being a hassle.. Newbie lol
I was having random crashing while gaming when using a single pcie cable and still when using 2 seperate pcie cables.
Only when I connected the pcie cable that came directly from inside the PSU to the GPU 8 pin connector. And the second pcie cable I connected to the rear of the PSU to the GPU 6 pin connector did the random crashing stop.
