Yep.Do the cores still down clock / sleep in ryzen master if idle when running all core OC?
Disable C states in bios maybe? But why do that? Your power usage from the wall will go up due to needing more volts when pc is idle. I actually really like that my cores go to sleep, it is a power saving feature and helps the cpu work less and also last longerIs there any way to stop that? I've tried bios settings and Windows/ryzen power settings but it always down clocks.
My understanding is the correct value is in Ryzen Master.I know it's not a bad thing, just wanted the option to test with some benchmarking.
Intrestingly enabling a bios setting global c states also Down volts the fixed vcore, shows it fluctuating in ryzen master but hwinfo just shows a fixed setting.
I have a 3600 coming tomorrow paired with a Gigabyte B450 AUROS Pro and 16GB of 3200 Corsair LPX.
Can anyone foresee any issues?
I didn’t realise about the BIOS issues until just now, the Gigabyte website does say that the board is “ready for Ryzen 3000 series” - I take that to mean it’ll be preloaded with a supported BIOS for this CPU?
Not had an AMD CPU since the FX8320 so looking forward to seeing the increase.
I thought it was possible to update the BIOS with no CPU on some boards?
its allways better to ask the reatailer to check for you
Ah that's where this may fall down then - ordered an x570 also just before the cut-off so will send the B450 back.
I have a MSI b450 gaming pro carbon, Ryzen 3600 and Corsair 16gb 3200 RAM coming shortly.
to go with my 2070 super ive purchased.
This will be my first AMD build, is there anything major I should be aware of with BIOS settings etc like getting my RAM to run at full speed?.
it is coming pre flashed so ready for Ryzen 3. So I don’t need to worry about this.
Thanks
No not really, just be sure you know how to install a CPU with actual pins under it because the last thing you want is bent pins, the memory uses XMP profiles just like Intel.
If you run into problems ask about that, there is nothing special or different to running an AMD system![]()
Great thank you, I’ll be sure to take a little more care with the CPU
hopefully going to notice a nice boost coming from a i7 3770 and DDR3 RAM.
Update the bios to the abba version so it boosts correctlyI have a MSI b450 gaming pro carbon, Ryzen 3600 and Corsair 16gb 3200 RAM coming shortly.
Thanks
