I can't afford the running/maintenance costs for the GTR... But where's the logic, a car with 200bhp more power is 1/4 of the cost.Clearly you're better off going for the GTR then.
I'd consider the 4wd panamera. 600hp through the rear wheels is undriveable. Even with the best rubber.That’s why I bought one. 3 year old 600hp supersaloon with a year’s manufacturer warranty for 30k. I don’t think anything else competes!
I prefer the F10 as it blends into the background a little more than the GC.
How much is a three year old Panamera...?
I dont get it either, i moved from a 911 turbo to an e92 m3 and my insure almost doubled. Must be something about the standard bmw driverI can't afford the running/maintenance costs for the GTR... But where's the logic, a car with 200bhp more power is 1/4 of the cost.
. A 3 year old M5 will be the old one though won't it, so probably why the value has dropped so much.Start from about 30k.
When will the new M3/M4 be released?
Google says mid2020 debut and you can get them in 2021When will the new M3/M4 be released?
Must be...I dont get it either, i moved from a 911 turbo to an e92 m3 and my insure almost doubled. Must be something about the standard bmw driver. A 3 year old M5 will be the old one though won't it, so probably why the value has dropped so much.
M140i is 1540£ and M240i is 1780£, Comparethemarket seems to be giving me the best quotes at the moment. It's looking more promising than 4k£Try an m140i? Might be cheaper a (insurance is weird)i essentially drives the same.
I had an m240i when was late 20s and a company car so not very helpful - sorry.
Meanwhile you just don't even want to know what it costs for a 730d. Which is mechanically no different to a 530d. Or a 330d really.
Probably why a lot of Alfa Giulia QVs (510bhp rwd) have ended up trashed... A guy on the owners club up in Glasgow flipped his one over onto the roof. That power needs to be respected. I can't find any 3 year old panamera within budget though and the interior looks quiet dated in them
Put simply, no.I want to replace my Fabia with something of a similar size so I’ve been looking at The A class, A3, golf and 1 series.
Ideally I want to spend 6 to 10k. I found a high miles (130k) 120i m sport which looks reasonable. Are they good reliable engines? A 120d with under 100k seems to be about the same price.
No they are not.
You're clearly not short of a few bob so why do you constantly fish in the bottom of the pond? Spend more and get something that's not a disaster waiting to happen.
