Is it the same panel as the Asus? Still keeping my hopes that it will have RGB and not BGR. Just need one big screen that i can do gaming but also office and programming work, means i need to be able to read the text without issues.
It is a variant of the same panel, but the BGR is related to the way it's mounted... i.e upside down. If mounted the correct way, it would be RGB. But as Azrael says, this has long been the way of assembly for larger TV's, so I don't know if there's any chance the CG437K will be any different to the XG438Q in this regard. The only hope may in the higher price tag, which is certainly not justified just for a brighter backlight, but may be because of extra costs in incurred in ensuring it's RGB. Long shot, but you've got to find a glimmer of hope somewhere amidst the doom and gloom of the PC monitor market lol!![]()
I'll never buy a monitor full price ever again. TVs all the way now. My Philips HDR 1000 I bought for £700 sold for £350.....It just wasn't good enough. This monitor seems similar. Probably same panel.
Keep monitor longer = Solved.
Yeah, funny enough, a lot of 43 inch TVs make better monitors for less money than a real 43 inch "monitor". There are a few irritating things though. On-screen advertising and menus get annoying, and TVs don't like to shut themselves off very quickly when the video source goes away.
I am very happy with my LG 43UD79-B, however it is honestly not much different from a TV that could have cost $100-200 less.
Didn't Acer advertise the 144hz version as having DSC though? Bit odd if it hasn't shipped with it...
On their official site and specs
1 - This device is designed to support refresh rate overclocking which may result in system instability. If unstable, reduce the overclock to a lower refresh rate through the on-screen display settings. User must connect two 1.4 DisplayPort cables to a capable device to achieve 144Hz overclock setting.
2 - 1ms VRB value based on internal tests under specific test conditions. Level of brightness may vary as a result of Visual Response Boost™ mode in use.
3 - Only 60Hz refresh rate possible via USB Type-C.
Acer only ever had a 144Hz version (CG437K P as covered in this thread) and as far as I'm aware never advertised or mentioned DSC. ASUS has the XG438Q (120Hz) and upcoming XG27UQ (144Hz + DSC).
