Caporegime
- 30 Jul 2013
I've had my 3900x since August, and I've not had many issues with it really, but after reading a few game CPU benchmarks recently it does appear that my minimum frame rates are lower than they should be.
I ran a few benchmarks when I first got it, mainly to check the CPU cooling was OK. I play at 4K, so i'm always going to be GPU limited, therefore it wasn't worth benchmarking a ton of stuff. At the time I noticed that in some games my minimum frame rate was a lot lower than an Intel 5930k that I used for many years, but I guess I didn't think too much about it as it wasn't apparent when playing games.
But Red Dead Redemption II just came out, and in benchmarking that I'm noticing the same trend again.
An example below
In the Red Dead Redemption II in-game benchmark I've done two runs, both with fresh install of Windows 10 and latest F10a BIOS with AMD AGESA 1.0.0.4 B and my minumum frame rates for 4k/ultra settings were 7fps and 6fps, respectively.
The average was about 43fps both times, which is more in-line with what others are getting with the same 2080Ti GPU
According to Gamers Nexus though, their 1% low and 0.1% lows didn't drop below 28.5 fps at similar settings:
I don't notice big spikes or drops in games, so perhaps I shouldn't even worry about it but it does seem like something isn't quite right.
What should I be looking at?
Spec in sig
An example below
Hitman 2 Miami Benchmark - Min 18.38 fps
Hitman 2 Miami Benchmark - Min 3.52 fps
Spec in sig
