Caporegime
 - 21 Jun 2006
I will be installing it myself. I just mean for the standalone system
Something like this seems to do push notifications based on Motion Detection, or is this cheap Chionese junk?
https://www.amazon.co.uk/SANNCE-Wireless-Surveillance-Auto-Pair-Intelligent/dp/B0716YV6PD/ref=sr_1_4?keywords=cctv+cameras&qid=1573051790&refinements=p_72:419153031,p_36:118669031&rnid=118657031&s=diy&sr=1-4
House is a small bungalow so no problem getting into the roof to cable, and not a problem for wifi signal either.
that is junk.
you want POE - network cameras. which are around £50-£100 a pop in the uk depending on the spec you go for.
then you will need an NVR with POE. Again another £150-£250 on top of the cameras when you add in a hard drive. then the cables.
