- 2 Aug 2016
I used to use flashing tape (cheap sound deadening. Dynamat stuff) that and a heat gun. Always worked for me.
Found the fuse, it has continuity. Now I have no idea...
I have the electric pump version.Had I known about these, clearly been around for years, I could have done my own oil changes. Oh the shame !!
Is there a Mellens guide for it? I've found that quite useful doing my MX5 loom.
I've used some from www.dodomat.com before - they have quite a range of products so might find something there that suits.Took my door cards off the wedge today to remove the metal trim for a refurb. What little material there had been to insulate the various apertures is now either well knackered or missing entirely.
I appreciate that any notion of actually 'insulating' this is an exercise in futility, but wondered if anyone could recommend some sort of waterproofing/deadening material here that I could stick on to reduce moisture and rattling a bit.
And yes, I was working in the car with the cover on while it rained![]()
Heater motor stopped working. Fixed it. AC stopped working. Haven't fixed it. Then the radiator blew up.
How do you find such wobbly cars? It's a super power!Heater motor stopped working. Fixed it. AC stopped working. Haven't fixed it. Then the radiator blew up.
It's ok. My crap X-man power is detecting left-handed people.Its a crap super power.![]()
I can't tell over the internet but you're weird so my guess is yesAm I left handed?
I'm third handed.I can't tell over the internet but you're weird so my guess is yes![]()
Amazing to say that despite it being 15 years old the hardtop electrics (cabin lights and
