Man of Honour
- 8 Nov 2007
- Outer Space
Disappointing….. you always have the option to post of their facebook or twitter as these tend to get a lot more views so they're more likely to respond.
Is it worth signing up to unsocial media to get a resolution...….. your call.
oh dear. I hope that this problem had gone away with that bad batch now being consumed and replaced. I just ordered some more kryonaut tonight!
I am now worried that I wont realise that I have a bad batch until several years down the line.They don't have their story straight unfortunately. They said just one batch from early 2018. Mine was from late 2017 (checked receipt and all). Then they (Thermal Grizzly) assured that all stock now at OcUK wouldn't be from the "bad batch" and that was wrong as well. Fortunately they seem to be making it up to those (who know they've been) affected and who would like compensation.
@TG-SupportI use Kryonaut, delid regularly, and never had a problem. Paste from an OcUK order dated 9th Jan 2020 resulted in the attached photoI didn't know about this issue so I emailed TG support to ask if they changed the formulation to be similar to IC Diamond and then found this thread. I then asked OcUK about this and they are aware of the issue and advised me to try contacting TG support again.
Thank you, I forgot to add the tag.
