Retail purchased so no NDA breach!!
https://www.eteknix.com/intel-core-...vlBjXnkjVHpXBhJ1Dcw_FzJeKWHGgTzt_KrKYr5iUohqI
That power consumption is really something else - 150w higher than ryzen 9
Looks OK for the money, stronger than TR 2xxx which I can't even buy anymore and much cheaper than TR3xxxx, Ryzen 9 is not an alternative due to lack of lanes. 4.9-5Ghz on all cores should go well.
thats going to need delidding for sure, unless there soldered ihs's.
TR3xxx isnt out yet , and these are pcie 4 lanes not the 3 lanes on the 10xxx;
also, 99% of users on HEDT are not under water, and the cpu alone is using 350w
Nice try Intel but the next generation Threadrippers are literally launching today so wait for those reviews before you decide![]()
intel are in serious trouble if the blurred bars are anything to go off the new threadripper is an absolute monster, plus it being built on 7nm power and heat should be better (maybee a lot) time will tell.
when's the embargo lift for threadripper uk time?
god looking at the power draw and temps, as said overclocked the 10940x pulls 450w holy **** compare that to the 3900x's pitiful 261w once its overclocked, and temps nearly at the 100 degrees mark, thats going to need delidding for sure, unless there soldered ihs's.
all comes down to cooler choice at the end of the day, but still the power draw of the refresh intel chips is embarrassing for sure, amd's 3900x/3950x sure looks like the better option for most people
Did i compute right? Over 170w more from 165w after oc. Defo custom loop.
