- 29 Nov 2019
Not yet but on the way. I honestly hope you can get one soonI take it you have got yours then!
Call it an early xmas present!
What cooler are people getting for their 3950x? I never had water cooling and I would like to avoid them if possible
im going to run a custom 360 rad with fans on silent ,ill see how it performs with the fans ramped up,if need be ive another 360 rad i can add to the loopWhat cooler are people getting for their 3950x? I never had water cooling and I would like to avoid them if possible
Same.mine doesnt come till tuesday.the joys of living in n.ireland lol
the very odd time if i order something on a friday it comes on a monday but it doesnt happen too much.dpd have screwed my last two deliverys up.one came into the depot at 4.30 in the afternoon i had another parcel due the next day and they delivered the 2nd parcel but forgot about the first one,it wasnt even on the van.last time i ordered ram it went to antrim depot instead of mallusk.they then sent it back to athlone which is 100 odd miles away instead of sending it to mallusk which is around 10 miles from antrimSame.
Yes I did just heard there can be issues with pumps and noise and leaks and a bit concerned as I plan to keep the pc for a few years. My current pc is from 2008 lol.Thought of a AIO cooler ?
yes both Programming, gaming and encoding.What did you buy the 3950X for, gaming, work or both?
Almost there. Just waiting for Cablemod and a few extra bits to finish up.
Is that the new xl version of the case or the normal one ? Looks amazing though
Thanks, pretty happy with the EK Solids Azure, too. The XL, the XE rad at the bottom makes it look smaller than it is.
